Quick question on SLI motherboards
Elemental
I have acquired an SLI motherboard, but it says in the motherboard literature that when using the board in SLI mode, the PCI-E slots have x8 effective bandwidth instead of x16. Now, I do not plan to initially use this board in SLI mode, because I only have one 7900gs, but if I were to add another one, would I be taking a large performance hit?
The board is http://www.newegg.com/Product/Product.asp?Item=N82E16813188007
The spec sheet on it is here: http://www.evga.com/products/pdf/131-K8-NF44-AX.pdf
I know it is not that good, but it was free. :p
Thanks,
Elemental
I think all the first generation SLI boards dropped the link speed to x8 in SLI. You won't take any kind of hit when you drop a second 7900gs in, even though each card drops to x8, you still have two GPU's and twice the ram, and the cards are connected at the top by the SLI bridge, so the two cards function as one. You would get more performance on a board that runs dual x16's, but the performance you'll gain in SLI mode will FAR outweigh the x8 drop.
Does having x16/x16 SLI ever dramatically help? I'm still looking for the answer. The new P5N-SLI board with the 650i chipset seems to clock well and is priced right, but will x8/x8 SLI hurt me? Any tests with high end cards like the 8800GTS/X?
