Quick question on capacitors on mobo.....
crazycd1
Long story short, I just got a pc in the mail and it had a large heavy HSF. It broke off and knocked 2 of the large capacitors next to the CPU sideways. I just pulled the board and the leads were not broke, so I just pushed the caps back in place. The leads were pulled out some, but slid back in the caps when I pushed on them....
Question is.... are the shot since the leads moved in and out of them, or will they still work? I would guess they moved about 5 - 8mm out, then I pushed them back in. I have not tried to boot the PC yet, no way to mount the HSF....
Any advice??
Where'd you get the PC from? If you bought it from a manufacturer, call up their customer service and ask them what they think.
The leads were pulled out some, but slid back in the caps when I pushed on them....Question is.... are the shot since the leads moved in and out of them, or will they still work? I would guess they moved about 5 - 8mm out, then I pushed them back in. I have not tried to boot the PC yet, no way to mount the HSF....
It might (but I doubt it) work for a bit but those are probally the filter caps for the cpu power and very shortly its going to go BANG.
A repair shop could find replacement caps and solder them back in but most wont take the time as they cant charge you enough to make it worth their while.
You could look at all the markings on the caps, learn what they mean and find replacesments somewhere like allied electronics, learn to solder and put them in. Total cost about $15 (includes the cost of a cheap 25W soldering iron) and a lot of your time.
If you post EVERY little number off of them you can find, I will take a look at finding replacements, a picture would help too.
Other than that, your borked.
you have three choices (since it was ebay I bet)
damage claim with shipper, I dont hold a lot of hope, not really their fault.
I have to make an assumption here and I dont like that but here goes.
Who ever shipped you that PC was an idiot if the heatsink was one of the large now popular tower deals, they exceed the specifications Intel provides for heatsink weight, you are lucky (actually based on what you are saying about no way to mount it, I wonder..) it did not rip the whole cpu and socket out of the board. Machines with those big heavy heatsinks should never be shipped somewhere with the HS installed. Oh most of the times it will make it ok, but if it goes thru the distribution center my son works at, LOL one good drop or toss into the back of a truck and its over. Talk to the seller.
Most motherboard manuf will repair a board (if its fairly new) for a flat fee (about $50) for out of warranty work (and this qualifies as abuse, its not covered) check the web site of whoever made the board and send a email to suport asking about out of warranty repairs, be sure to inclue the full model number of the board, it should be on a sticker or printed on the board somewhere.
