Quick Question about Updating BIOS on DS3
xenithon
Hi all. I am going to build a new system in the next week or two. It will be a fresh build and install and want to flash the BIOS to the latest version before any OS/software installation. Board will be the Gigabyte GA-965P-DS3.
I do not have, and will not have, an FDD drive in the new system. Will I be able to boot off a USB key to flash it? Will I need to format the USB with some sort of DOS/bootable image so that the PC can boot up to a prompt? I believe on that key I will then just need to put the Gigabyte flashing utility and the latest image, correct?
Alternatively, I remember some motherboards I used in the past allowed you to update the BIOS from within the BIOS (as one of the options). If that is they case, can I do that with the DS3 using a USB key or even a CDR?
Cheers,
X
PS. one last questiom: if using the ICH8 SATA controller (which I believe is better than the Gigabyte controller) for a non-RAID setup, do I need to create a driver disk for an XP install again or will the SATA HDD be recognised?
The bios will see the drive without any special drivers needed.
install the raid drivers at windows install even if you dont use it.
I dont know about the usb drive.
There is a utility in the bios (from main menu) to flash the bios and you should use it, never use the windows or automatic update software, it is broken and has killed boards. Even if they fix it, dont use it.
You dont want to hear it, but buy a floppy, you dont have to put it in the case, just take the side panel off, set it on a box or something and use it, when done, take it out.
I would install the gigabyte raid driver in the initial windows install and the intel one, I did, even if you dont use it. Then in bios set the option to ide/raid on the gigabyte controller, It reconized my cd/dvd burner with no problems and in udma mode. I too put all my HD's on the ICH8, but just in case the raid driver is in the system.
Hopefully someone has done the USB - CD thing, all that is needed is the actual bios file by itself if you use the "in the bios" utility but I cant remember if it gives any options as to where the file is. I will check.
In the actual utility (I went an looked) all it want to look for is a floppy, with a data cd in the drive it was not allowed as a option to look at anything but the floppy. I also (gasp) checked the manual which never talks about anything but a floppy. I dont have a thumb drive and the bios utility does say to hit tab to toggle between drives so there might be some hope. /shrug.
Sorry could not be of more help.
Bill is right. A floppy is the way to go, it seems as though I have learned that the hard way :(
Go to www.bootdisk.com
Download the "No 1.44" file (cdflash.zip I believe)
Burn the .ISO found in cdflash.zip to a CD (obviously)
Burn your flasher.exe (i.e. awdflash.exe) and bios.rom file to another CD.
1. Boot computer using the ISO disc you created.
2. See the DOS prompt? GREAT
3. Swap discs
4. Flash BIOS
