Look at the black housing the power LED connector (The 3 pin one). See how on one side there are little flaps, and you can see the pins? Well, with the tip of a small knife, lift up on one of the flaps GENTLY and pull out the wire that it goes to. Then simply put the wire in the other open hole. Voila! 2 pin power LED connector!
