Quick help INFO
The 6-pin power connector you're talking about isn't for your CPU, it's the PCIe graphics card power connector. If you have a PCIe power connector, you should have at least a 4-pin Aux CPU connector, if not two of them that would fit the 8-pin CPU connection. You can buy an adapter online, or just try it with the 4-pin (I've heard that does work in some cases).
no i know about the 6 pin connectors for my Video cards in SLI... but for the CPU power mine is a 6 pin coming off my PSU and the mobo has 8 pin.. I have and I Star TC-700PD2 thats my PSU... im still confused
Are you sure you just don't have 2 different PCIe video connectors? I can't think of any reason why the Aux 12V CPU connector would be 6 pin.
This description seems to imply it has dual PCIe connectors, but you should also have an 8 pin AUX CPU plug in there.
The PD2 high performance power supply series sets new standard in server and industrial power supply. It supports newest motherboard connectors of 20, 24, 8, and 4 pins. In addition PD2 series power supply also comes with dual PCI-Express connectors to enable intensive graphic application and four SATA power connectors for the latest storage interface. The dedicated quad 12V rail design added extra system stability and lower thermal dissipation. 80plus high efficiency power supply saves on electric bills and less cooling requirement. PD2 is the ideal power supply for high-end gaming workstation, and server power supply.
http://www.rackmountnet.com/Power-Supply/I-STAR/I-STAR-PS2-700W-Power-Supply-TC-700PD2/
