Been fighting the heat with Ivy since I got it like everyone else. Just using my H100 right now for initial testing. I was seeing how far I could get with no HT, and at 4.8Ghz 1.385Vcore, I was hitting 93C
I realised one core was way down at 77C though, so I figured Id better check the TIM.
I had done a simple dot in the middle, and boy was that a bad idea. Got out my spreader that came with a tube of TX-4. Spread out a nice thin, very even layer, the exact size as the contact area of the IHS. Now, hottest core is 68C, coolest is 62C.
So, quick tip is, dont do a dot in the middle. Spread out a very thin, and very even layer on your heatsink. Press/clamp/screw it down on the CPU first if its new to get that indentation of the IHS on the heatsink so you know what area exactly needs to be covered.
Remember that the Ivy ide is a long rectangle shape in the center of the IHS, so a dot wont get to the ends. A line might work, but you want as much contact as possible with the full IHS. Dont leave any not making good contact.
