rage4order
- Oct 4, 2004
I was wondering if it is safe to plug in an SATA hard drive into my computer while it's on, or should I shut it down? I hope that's not too dumb of a question...
Ok, just wanted to make sure before I jacked something up. Thanks.SATA is hotswappable! Go ahead, your only worry is being in the case and touching something else, so be cautious!
No, you cannot. Hotswapping is only possible when AHCI is enabled.You can unplug/plug any time with SATA any version
