Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Just wanted to know if anyone has seen or heard of any of this sound card (Audigy 4) going to PCI-E, or know of any PCI-Express Sound cards that may have already hit the market. Thanks!
I e-mailed creative, and the quote was: "With regards to the issue you are having, I am afraid there is not released plans that the Audigy 4 Pro will have a PCI-Express format available."
Also they mentioned to check and see if the board I was using is PCI backwards compatible. Oh well... I may have to contact shuttle and see if their SN25P system is backwards compatible.
It is not- PCIe only, a 1x and a 16x. AFAIK, there are exactly no PCIe soundcards on the market- as for sound quality, the solution in the SN25P rates as the best available on board. Don't get your hopes up for Creative to release a PCIe card anytime soon- the next product will be PCI first followed by PCIe.
