Questionable HD Tune results for flash drive
hiodie
This isn't a problem, but more of a curiosity, but what is the fastest a flash drive can do? I know I have seen flash drives in the low 30 MBps, but I ran my Rally2 (not turbo) and it is giving me 39 MBps, 0.4 ms access time. Other flash drives are much slower (and older). I have ran it a few times with the same results. Is this possible? Reviews of the drive show it around 32-33 MBps.
HD Tune results
Is this a USB device? If so that is darn good and about the maximum speed that you can get on USB 2.0.
USB, yes. I kind of thought it was reaching the limit too. I will having to time a file transfer to see if it matches up.
EDIT: Timing the file transfer I get ~31 MBps, but the windows transfer box never shows below 38 MBps. I am not sure if timing from the second I release the file to the moment the transfer box disappears is accurate, but that is how I did it.
That's extremely fast for a USB device. And I wouldn't put too much faith in the way Windows measures the transfer speed. Use a program like TerraCopy instead. I've found it to be much more accurate.
Weird, maybe you lucked out and got a particularly good one... What are the write speeds like?
I stuck a G1 Intel 80GB in a USB 2.0 enclosure and that maxed HT Tune at 33.3 MB/s. That is a really a good transfer rate!
Write was around 13MBps. I will look into TerraCopy and maybe some other free HD testing programs.
13MBps for writes is decent, tho not as impressive as the 38MBps reads. My Class 6 SDHC cards are usually over 10MBps write and around 20MBps+ read, I'm not sure I've got any actual flash drives besides my Creative MuVo V100 MP3 player (which has pretty poor write speeds but w/e, it's only 2GB and I just use it for music while I run).
