Question on replacing a mobo
third question before I forget...I've got pc2100 ram in this thing, and like I said, would rather not have tobuy anynew ram...it's fine for what I use it for, so any mobo replacement would hopefully use what I already have. Also, an AGP vid card in there, no need for anything fancy or upgraded.My upcoming system purchase will be handling that.
Its doubtful that your psu and mobo went out at the same time, i say try out the new psu and see what happens from there.
Sounds a little like you have the upgrade fever and just want some new toys :D
And there is nothing wrong with that!
if you can get a nforce2 board, get it. stay away from the via chipsets. if you cant get a nf2, try the sis chipset.
Look in FS/FT threads. I'm sure you can get a socket A board for pretty cheap. Probably $20 shipped will get you a board that will replace the one you currently have seeing as it's an old 133 FSB chip (IIRC ;) ). Probably was running on a Via KT266 chipset.
