case sensitive
- Dec 21, 2012
Even one error means the overclock is unstable. What I meant was start from 155 x 25 and work up (sorry, my bad for not explaining this). This way you can be sure a lower clock is stable and work your way up rather than starting with something unstable and trying to stabilize it.
Also, what voltage have you set in the bios, there may be room to increase it.
Those temp readings in RealTemp seem off (way too low). If you click on settings, what TJ Max does it show?
