Question on Display Setup
AthlonXP
Ok Guys, I picked up a Samsung 32 inch 1080p LCD. It has 3 HDMI ports, I am using 1 for my xbox 360 and the other 2 I want to use for my pc's. The problem I have right now is that When I use the HDMI to dvi adapter to my GTX280 video card the display looks horrible. Now if I use the vga port that comes with the LCD the picture quality is good. Just wondering what that could be. Oh yeah the TV is this one:
http://www.crutchfield.com/S-xWM1HM5EKYP/App/Product/Item/Main.aspx?I=305LN32550
I'm assuming that you are using the nVidia supplied DVI to HDMI dongle?
nVidia has a nice feature in their control panel that ATI doesn't have. It's in the nVidia advanced control panel under "TV output" > "advanced color settings" I think.
It allows you to select the TV Out signal over HDMI. There are two choices: RGB and YPrPb.
I just bought a 9600GT and checked out both settings, and the YPrPb caused blurry red text and a tiny bit of red/blue noise around black on white text. The RGB setting did not do this.
Can you take a photo or describe the problem? Are there black bars around a 1920x1080 image? This might be an overscan/underscan problem with the TV. There is a "just scan" setting that changes this too.
Good luck.
