For Christmas I got an Intel 120gb SSD and a Win7 64. Im pretty excited to get this installed. Currently I have a WD 640gb harddrive in my pc which will become my secondary storage drive. My question is, what is the best way to do this swap?
I was just going to remove my old harddrive, put in the SSD, install Win7, my drivers, etc. Then re-hookup my WD drive. Now although all the programs and such will not work my pictures, video and such should still be on it correct? And can I just delete all the program and windows files?
Or is there a better way by backing up first then reformatting the WD drive?
I was pretty confident the way I mentioned above would work preserving the files I wanted to keep, but being paranoid I decided it was best to just back-up on an external drive first, then do the swap, but the problem I ran into while backing up is an I/O error when it gets to all my home movie video files. Everything else, pictures, saved docs and programs I had transferred over fine, and still do , but the video files which are larger files keep giving me this error. A search on the internet wasnt much help, some possible solutions was to shut off system restore, but I had mine shut off already, and then make sure Windows updates are current. I did all my updates and it still wouldnt back up my vid files. Im currently using Win Vista 64.
Thanks in advance.
Thanks in advance.
