Check to see if the pin layout is the same. From what I've seen they look identical. If you're hesitant to use it, call them up and check if they'll warrant the psu if you use the replacement 24pin cable and kill it.
I'm sure it'll be fine tho.
IKR thanks for the help!True. Double check and be sure the pin layout is identical before using the cable. I'd also double check with Corsair's tech rep.
Can't be too careful![]()
