aransamus77
- Nov 29, 2024
HD Tune is good software for Full Surface Scan for HDDs 2.5" + enclosure case USB 3.0?
good, you shouldnt, its programmed by idiots.I do not trust chatgpt
Sowing keywords. Someone will type those things, specifically the product and place, it will pop up - bam, credible.i mean all your questions in all the various threads youve started. whats the point behind it all?
then the drive probably is fine BUT you should be testing them with a direct connection to the mobo not via usb.
