TSS Modder
- Jun 29, 2004
there was a post over at anandtech forums i was reading about ppl constantly having issues w/ running games and CPU intense programs. im also hearing a few instances of problems w/ ppl here.
my question is those who bought X2s, did you reinstall/clean install windows or did you just update the BIOS and stick it in?
a lot of the time it appears that the ppl simply updated and stuck the CPU in w/o wiping the PC. im currently looking into buying a X2 3800+, as long as these problems are solved. i just want to see if its AMDs fault, or if ppl are just stupid.
btw, if anybodys having any issues w/ their X2s, i recommend using the X2 driver: http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_13118,00.html and maybe an affinity setting program: http://www.majorgeeks.com/WinLauncherXP_d870.html. both are extremely helpful. the driver should get rid of most of your problems.
