- Dec 3, 2006
-- What your budget is (and whether it includes taxes, shipping charges, and/or other costs)
A total of $500 or less
-- Which parts you need within that budget
Motherboard
HD
PSU
Ram
Cooler
-- What the system is going to be used for
Gaming
-- All of the components that you already have and/or are planning on reusing
samsung t260hd
-- Which components you are considering getting (list out your components with model numbers/names along with links to the stores you're getting them from)
intel core2duo e8400 (used $110 max)
evga gtx260 core 216 (used $120 max)
Microcenter has dvd drives for 20 after tax around $22
Fry's has antec p182 for 70 so after tax around $75 (i had this for my first computer and its really quiet... i love it but i'd love any other case that is very quiet)
-- The question(s) you have -- or, the reason you made the thread in the first place
So i got around 175 left to break down for mobo, psu, ram, and hd. Is this possible if i'm shooting for a decent mobo and a psu that will support the 260 with enough ram to run things smoothly? Also i have no idea between the difference between a c0 step and the e0 step (which one is better?) Not sure how many watt psu i'll need for the 260 and i'm no pro with a mobo either =\ definately willing to buy parts used and utilizing a smaller HD. Any advice would be helpful! thanks!
Motherboard
HD
PSU
Ram
Cooler
Gaming
samsung t260hd
