Question about xfire mobo
In that price range, and since you're getting an ATI board. I'd probably get either a 256mb X1950 Pro or a 512mb X1950GT. If you can find a X1950 Pro 512mb version in that range with a rebate, I'd probably get that.
It will run with only one video card without any problems.
Your memory should work, but I'm a little confused because I haven't seen very much DDR2 400mhz memory. The usual minimum for DDR2 is 533mhz. I'm wondering if you have DDR1 memory instead, and that definitely wouldn't work.
yea its DDr1 =[ do you know some bomb deals on 1Gx2 dual channel ddr2 800mhz?
