Question about "wireless" printers.
Kabob
My wife and I are looking at this printer and we've got a question. I hear a lot about "wireless" printing, is that referring to the ability to print over your network or the printer having built in WiFi? If I can print over my network with a CAT5 cable that's fine, if the only way to do it is with USB hooked up to my PC that won't work.
Can anyone shed some light on this?
Wireless printing means that the printer has built-in Wifi. If the printer comes with a NIC, then you can do network printing which lets you prting over your network.
if the printer has built in wifi then it just pretty much connects to your wireless network and then any pc/laptop/netbook on the network can print on that printer without having to be directly connected via usb/cat5.
