Nightwings
- May 1, 2007
I just got my two loops put together and went to flush one with some water only to find the pump wouldn't power up when I turned on the power supply. I tried different molex's in case it was a bad one but nothing. Then I check the other one and it don't work either.
Is there some trick to starting these up or did I manage to get two bad pumps?
