chaarlieee
- Feb 8, 2008
Edit: nevermind... found my answers through searching
No... the OS is not bios locked, it is no different than a retail copy other than the EULA you agree to when you install the OS. If your hard drive fails, just re-install XP, no special steps required. You might have to call MS to re-activate, but that should be the end of it.
I'm not sure how to answer the second part, I don't think I understand exactly what your asking... If you mean installing the same OS on multiple computers at the same time, the only thing stopping you is the fact that it's illegal... and perhaps activation problems...
That's how it will work, assuming you have it only on one computer.
