Tony Rotten
- Apr 23, 2008
I guess I don't understand well the consequences of using a mirrored pair of disks. I have the 2 e-SATA ports of an Intel DX38BT MoBo in RAID 1 (Marvell controller) configuration. (Two 750GB drives.)
All this time I thought that the catchphrase "hot swappable" at least meant that if I took one of the hard drives out when the PC had been turned OFF normally, that the disk that I took out would immediately work in a second PC upon installation, showing ALL data (i.e., directories and files) as the mirrored pair showed in the original PC when in operation.
No such luck. Twice did this not work. Upon starting another PC with the former in-a-RAID1-array-disk, Win7 64-bit reported "RAW" status on the disk with the corresponding loss of data.
What good is a RAID 1 array if the data in the drives is not recoverable when simply removing one of the disks (with the PC OFF no less).
Am I doing something wrong? I thought that MoBo-based RAID was superior to say, Win7 way of doing it?
TIA
TIA
