Ok, so with the following components, do you think im atleast at 1/2 of 700watts?
I
MSI p35 platinum
C2D E6420 OC'd to 3.2ghz ( that should bring up some power usage)
Geforce 8800 320 No-OC
2g Ram @ 800mhz
SATAII HD
DVD-ROM
Case Fans
The reason im asking is because I have a 500watt(Xclio) PSU and a 700watt(OCZ GamerXstream) PSU. The 500watt dosen't have the EPS12v 8pin connector which is why I got the 700.. really im just wondering if I should return my 700 if its going to end up costing me more per watt..
