Viper87227
- Jun 2, 2004
I am making my first venture into watercooling, and I must admit I am slightly neverios about the whole thing. I am getting this kit:
https://www.dangerdenstore.com/product.php?productid=12
Then, I had a few spare bucks to spend, so I was gunna get some UV 1/2" tubing and a tube cutter from frozencpu, but then I saw this:
http://www.frozencpu.com/ex-liq-04.html?mv_pc=117
This stuff seemed like the answer to my prayers, as it would remove all my worries of going to a watercooling setup. I was about to order, and then something dawned on me. That 4oz bottle of coolant that comes with the kit. I am assuming that coolent is something you would mix with water to help it cool better, correct? Well, what about the Fluid XP? Anyone know if that coolant that comes with the kit is conductive, coz that would ruin the idea of non-conductive water. Also, if I got the FluidXP, would I even need the other coolant? Also, I believe that bottle is a half gallon. One bottle will be more than enough right?
Any help woudl be appriciated, I would like to get this ordered ASAP.
