I just recently built my first computer! But in the process I might have messed up when installing the Intel CPU fan.
I bought a e6600 and used the fan that came with it.
When I try to take it off the instructions says to unscrew the connectors 90 degrees. It seems like I can get two to pop off correctly but the other two I can not. Did I break it? Or is there a way I can get it apart without messing up the motherboard. I'm planning to get a better cpu cooler so I can overclock hopefully.
