- Sep 2, 2004
So, recently I got a new case and some new fans to improve my cooling/noise situation. I'm using a Fractal Define R3 with a Kuhler 620 and a GT AP-15 pulling through the radiator and exhausting out the back. I have another GT-15 currently in the side panel pulling in (I didn't have the proper hardware to mount it for push/pull so for now that's where it is). When I have the machine running, I can barely hear the AP-15 behind the rad at all, but the one in the side panel makes a pretty audible "humming" noise. It's not just like a low air movement sound like the other AP-15, and it's actually pretty annoying. I've got the radiator AP-15 running off the Kuhler 920 connection, and the other one running straight off the motherboard.
My question is, is something wrong with the other AP-15, or is it just somehow running faster than the other one and thus making more noise? I've never used AP-15s until now so I'm not sure what they're "supposed" to sound like. Thanks for any help.
EDIT: According to SpeedFan (which I don't know is accurate since the fan is passing through the Kuhler 620), my CPU fan is 1400 RPM, which is quite a bit less than the 1850 the AP-15 is capable of. I guess I may just have to stick the other one on a fan controller.
