Hello, I am one of the few (or many?) around here that own a 6800 GTO, I am able to unlock to 16/6 flawlessly, although the reports seem to be that after mid-october dell/nvidia started to prevent unlocking and I bought my system in late october (shipped the 25th) so thank goodness for that. I am also able to get an OC of about 435/1100 stable with no artifacts, so my question is...Can I flash this to a 6800 GT PCI-E? I have the 6800 GT PCI-E Bios Rev 1, and seeing as it doesn't seem that my card cannot surpass/be unlocked to a stock Ultra let alone a GT, I'd like to know. I tried to test using the vgabios tool and my system reboots but I'm not sure if it works/supports the 6800 series, so I'm unaware of whether the problem is the tool or if the card will become fubar'd by flashing. Anyway, sorry for rambling on, any help will be greatly appreciated and welcome. Thanks in advance for any advice/comments
*EDIT* So I realized I needed to use VGABIOS in DOS, doh. So I loaded up DrDOS and I tested the PCI-E GT bios, the screen refreshed, and it said it had loaded succesfully...I am not familar with this proggy, does this mean it was successful? Is the bios only loaded into memory while in DOS, or is it suppose to carry into windows (I doubt that)?
*EDIT 2* Ok, I really have to stop editing but I have just tried to load a completely incorrect bios, it wasn't even for the same series of GPU, and it gave me garbled madness followed by the screen shutting off. So I will continue my test with a non pci-e GT bios and see if I get the same result. So far it looks as if I just may be able to do this flash...could just be foolish optimism though
- - Alright, a non pci-e bios also loads without a hitch. I know if I were to flash I'd have to use the pci-e version, but I was just curious as to whether anyone finds this suspicious? Thanks.
