question about ASUS A8N5X
drunkenpanda
It says that it comes with athlon 64 x2 support, but a few people said that you need to update bios first. anyone have this problem before? would i need a regular 64 cpu to update the bios first before putting in the x2?
also, is the sata150 upgradeable to sata300 through bios? will my sata300 hd work on this?
also, i have really old ram (i bought it 2 years ago). will my performance suffer?
I just bought the same mobo a few days ago and it works with my x2 without any bios update. I dont know about the other 2 questions though.
I would think that you should be fine without a bios flash unless you're getting some very old stock from somewhere.
I'm 99% sure your HDD will work (at SATA150 speed). AFAIK, you can't update that via bios since it is a hardware issue.
Your memory won't hold you back too much. The memory controller is very efficient. You can just run a divider and you'll only miss out on maybe 1-3% of the performance. Your memory bandwidth won't be as high, but unless you're doing a lot of synthetic benchmarks, you won't really notice a difference.
