question about artic silencer v.3
LightSwitch
is it possible to fit ramsinks on your video card with the silencer mounted? or does the silencer do a decent job by itself at cooling the ram? thanks
Yes it is. I used the OCZ Copper BGA RAM sinks, they fit snugly under the cooler. Make sure you install the RAM sinks first!
