First post, please be gentle.
I have the PSU listed in the review here (mine is 3 years old) and I wanted to make sure it would work with my new EVGA GTX 280 SSC that will be arriving next week. I used Google as best I could, but managed only to get conflicting information.
Current rig is: Q6600@3ghz (stock volt), 2x2 gigs DDR2 800 mhz RAM, 3 HDs, 1 DVD/CD burner, 3 120mm LED fans (from Antec 900 case), and I have two external HDs i connect sometimes.
If I do need a new PSU, any recommendations for something of quality but cheap (College student) that will run everything for the next 2-3 years A-OK, even if I added a hard drive or two later on? I have no intention of ever running a SLI configuration if that helps.
Thanks in advance!
Thanks in advance!
