Question about a DFI Mobo
iono about the new revision, but in when the first batch of ultra d came out, there was this simple trick to convert it a SLI mobo...
don't know if it still works on the newer ones
Doesnt work on mine/
Are you sure you did it right? I'm only asking because there haven't been any reports at all of this mod not working (human stupidity excepted) on DFI-Street. I would think they would be the first ones to know about something like this!
EDIT: Apparently the only thing nV started doing to the chipsets was plopping some epoxy on the contacts that get bridged in the mod. That shouldn't stop you though- it scratches off easily.
I donno maybe ill try and cut the solder again and try it + see if any new BIOS would help.
Why? Just get the SLI-D instead. Probably cheaper anyway than the A8N-SLI Prem.
Well i tarded my iXPS2 online with someone, and i think i have the SLI Bios because when it boots there is a mention of Nvidia SLI.
