question about 64bit guests on 32bit hosts
goodcooper
i know it can be done with a machine (cpu + bios) capable of VT, but what about memory addressing...
can a 64bit guest address the >4GB that the 32bit host cannot?
No, the virtualization software running on the 32-bit host operating system can only use as much ram as the host OS can give it.
Not true :) Since you're passing the cpu through, you can use the full 64bit range.
So if I have a 12gb box with XP 32bit on it, windows seeing 3.25gb when booted up, I can make 2 other Vista64bit guest with 4gb each?
I suppose that you could, but that doesn't make a lot of sense to me since the host OS, afaik, is still telling vmware/virtualpc/etc what kind of hardware and such is installed. For instance, I can't connect my iphone to a guest OS unless I have itunes/bonjour installed on the host to pass it through to the guest.
the real question is, why would you run 12gb of memory on a 32bit os? :p
And VMware is ignoring the host OS and talking directly to the CPU :)
ESX 3.X is a 32bit operating system, for instance, too ;)
So would this be the case on a non-vt enabled chip as well? How does it determine how much memory to save for the host? My experience with virtualization is limited to basic/home stuff
I stand corrected lol
Non-VT won't be able to run a 64bit guest on a 32 bit system :)
Yes, a 64-bit guest running inside of a VM on a 32-bit host can use 64-bit addresses for memory access. However, that address space has to map to physical RAM somewhere. In a hosted system such as VMWare workstation or Server, the host OS manages the mapping of the VM process to physical RAM. Thus, the VM process can only physically address a 32-bit address space.
so if I understand you correctly, as long as the (32bit) host can use tricks to address all of the memory space, then you can run a 64bit VM with no memory limitations, but if you're using something like XP as the host, you'd still be bound to the 4gb limit?
sec...
edit: Yep- this is one of main advantages of VT- it lets the VM use the CPU's memory adressing range, regardless of the host OS. I just built, installed, and ran a Vista64 guest with 6gb of RAM on my XP32 machine. It saw, identified, and used all the memory without an issue. In VMware workstation.
like I said - VT lets you ignore this limitation - it passes the VM process through the host OS straight to the hardware, letting you ignore those limitations.
If you have VT, there is no limit for your VMs. :)
oh ok, thanks for the clarification :) it's good info to know
edit: sorry op :D
