PatchRowcester
- Sep 2, 2012
Hello all,
I have a question regarding 144Hz monitors.
I currently use this monitor:
Hannspree HZ281HPB 27.5" 1920x1200 Monitor - http://www.newegg.com/Product/Product.aspx?Item=N82E16824254052
Now, I am told that a 144Hz monitor is plainly superior to a 60Hz monitor. I play a lot of shooters, BF4 primarily. Would the performance gain be justifiable to make a purchase of a 144Hz monitor? Is it really that good for gaming?
I am condering these two models:
ASUS VG278HE - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236293
ASUS VG248QE - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236313
Assuming that the performance gains are worthy of making the switch, which one would you recommend? If neither of these are good, is there one would you would recommend?
Thanks.
I am posting this on PC Gamer and on Hard Forum.
Thanks.
