ok here is the thing
some people on here praticaly screamm "71 degrees is the absolute max your chip should run otherwise its dangerous"
many people quote their temps and dont say how they are monitoring or what with.
for example my g0 q6600 (420x9@1.5v) on full load of 4 cores for 3 hours in -
CORETEMP: 78 degrees
SPEEDFAN: 63 degrees
UGURU: 63 degrees
so while i love the 3.8g quad speeds i have clocked back down until i sort out my temps as i like to er on the side of caution.
BUT which temps are the temps that should max out at 71ish?
is it coretemp temps or speed fan temps?
i know coretemp is higher as it measures from a different senso on each core and the speedfan and uguru read from the traditional socket temp the i have been used to readng off for years. but does that mnean that back in the day when my p4 was its 40's that it was actually 55 for example but i didnt have coretemp or in core readings so i just didnt know?
in this case you would sy its safe enough to run 78 maxed out in core temp. [edit: ah, not neccessarily as they were different chips but you get the idea of what i am saying!]
can someone set me straight! thanks
oh and for all you quad core oc'rs please state what utiliy you use to get your temps instead of "yo my quad @ 4gig 55 degrees load yeehah" thanks!
UGURU: 63 degrees
