After completing the SR-2 based Chess server, now it is time to experiment with a quad Opteron Server for chess.
luck smiled on me and a fellow [H] sold a few Extra Spicy Opterons, which are pretty much the only CPUs that can (possibly) beat my SR-2 in price vs performance for chess servers.
The case is an Aerocool Strike X ST
water blocks: cuplex kryos Delrin für Sockel G34, G1/4 this was the only place where i could locate 4 blocks for G34
radiator and fans: Bundle airplex PRO 240 G1/4 + 2x airstream 120 mm
this one was easy as well, since i was looking for quiet operation. that ruled out high FPI and thick radiators. I do know that 2x240mm is overkill for a server without a gaming GPU, But 2x240 low FPI, not so thick gave me better sound/temps than a high performance 360mm rad. The airstream fans are so-so, but their price does not hurt
pump and monitoring: aquastream USB 12V pump - Ultra version I need remote monitoring and control, and the only software solution that i found was this Eheim based solution. If there a way to monitor and network control a loop using a D5 pump, i would like to know how it compars to AC software.
|Reservoir: aquainlet XT 150 ml with nano coating, fill level sensor and LED holder, G1/4 a fill level sensor monitored by software was too cool. Plus this reservoir combos nicely with the pump, saving space and reducing loop restriction
Subtotal: 352,27 EUR
Would you choose anything different?
Do i have enough pump?
martinsliquidlab say that dual pumps in series adds reliability, but i have heard that when one pump fails the other faces even higher restriction and ends up failing as well. i have an spare DDC ( inside an apogee drive block) that i could mount in series. Would you add another pump?
and finally, the part i do not get at all: choose barbs for blocks and tube.
i am loost in the alternatives. i tend to favor 3/8 and 7/16 ID, but won't refuse 1/2 ID.
I am too stupid to actually locate and source compatible barbs, adapters, fittings and tubes. what goes with what. by all means put me away from any stuff that can cause galvanic corrosion, only silver and brass connections please, not F. nickel plated gunk.
The pump has an optional flow sensor. What is the need of this? I already monitors the temps, pump and water levels. why do i need to monitor the flow? Is that worth the + 10% total build cost?
finally, loop design:
rad1 > reservoir/pump > CPUs 1-2 > rad2 >CPUs 3-4 >rad1
is that the optimal solution?
