Quad Core Upgrade, need [H] advice.
Cmustang87
Hey all, today is the day I break down and buy my quad core rig. This is what I'll be getting. I will be overclocking my CPU, so please tell me if there will be any issues with what I have chosen for components.
P5Q Prow/ Antec 1200 ($289 Combo Deal)
QX6850 (Retail Edge)
G.Skill 2x2GB DDR2 1066 2,1v 5-5-5-15
VisionTek 4870
Corsair 620hx PSU
WD6400AAKS
22" Samsung Widescreen
Tuniq Tower 120
~$1400 - That is my budget. What do you guys think? Does the Tuniq Tower work just fine on the P5Q, what else would you reccomend for a HSF to cool my QX6850 @ around 3.8.
Thanks in advance. BTW, I'm upgrading from an AMD 64 3000+ AGP Rig.
EDIT: I will be gaming on this rig obviously, and I will be using Vista x64. If I can trim some fat off this please let me know.
If you're only using one optical drive and one hard drive, you could trim a lot of fat off by getting a smaller case, like the Antec Three Hundred. Even without the bundle deal, the P5Q Pro and the Three Hundred combined would be much cheaper.
What about heat in that case coming from the CPU and room for the 4870? Those were my concerns.
The Three Hundred has room for everything plus space for two additonal 120mm front-mounted case fans. Pick up a couple of Yate Loon or Scythe Slipstream low- or medium-speed fans and you'll be set for the most part.
The Tuniq Tower 120 is a good choice, but for a cheaper, lighter alternative, consider the Xigmatek HDT-S1283 and its ACK-I7751 retention bracket.
I currently have an Antec 900 and I see that Newegg has a rebate on it. Get it for $79 AR. I really like my 900, but I"m selling that rig, will the 4870 fit in that case?
Yes; the 300 is designed to be the smaller version of the 900.
If you're selling your old rig, I suggest keeping the 900 for yourself. (If you're selling it here, most buyers would prefer that you part everything out.)
You could also get the HX620 for a bit cheaper at Buy.com.
I'm selling the rig as a whole to a friend of mine for like $350. I didn't want to make him pay for a new case.
Is that the best price/performance motherboard for the QX6850?
It depends on what you want to do with it.
Danny Bui said:
Gigabyte GA-EP43-DS3L Intel P43 Motherboard - $90
MSI P45 Neo3-FR Intel P45 Motherboard - $112
Gigabyte GA-EP45-DS3R Intel P45 Motherboard - $128
Asus P5Q Pro Intel P45 Motherboard - $140
Biostar TPower I45 Intel P45 Motherboard - $150
DFI Lanparty DK X38-T2R Intel X38 Motherboard - $180
Asus P5E Deluxe Intel X48 Motherboard - $220
DFI Lanparty DK X48-T2R Intel X48 Motherboard - $220
Gigabyte GA-X48-DS4 Intel X48 Motherboard - $225
Just to help you out: All of these motherboards have PCI-E 2.0 which may be useful for future GPU upgrades. If you don't need RAID, more than 6 SATA ports and only need semi-decent overclocking, check out the DS3L. If you need 8 SATA ports, RAID, 4 PCI slots, and legacy ports, then get the Neo3-Fr. If you don't need more than 6 SATA ports but want RAID, firewire, a second PCI-E x16 port, a second gigabit port, support for 16GB of RAM, optional eSATA, x8/x8 Crossfire, and great overclocks, then get the DS3R. If you like the DS3R but need 8 SATA ports, want an onboard pre-installed fast booting Linux setup, just support for 8GB of RAM, and don't need a second gigabit port, get the Asus P5Q Pro. If you want a motherboard with excellent overclocking capabilities above all else (feature wise), go with the I45. If you want Crossfire with full x16/x16 bandwidth, get the Lanparty DK X38. If you have cash to burn, need x16/x16 Crossfire, and don't give a damn about getting the most value for your money, get the Asus, DFI, or Gigabyte X48 motherboards. Do note that the Asus website can be slow sometimes.
Yea, I don't need to RAID, but I may xfire in the future. I would like to crank that QX6850 to near 3.8 or so. I was thinking the P5Q Pro would rock.
Will DDR2 1066 RAM allow me to do that? I've never overclocked before and I'm completely new to it, so any info on that would help as far as components.
Actually DDR2 800 RAM would allow you to hit 3.6Ghz or so. Some math:
Stated FSB/4 = Actual FSB
Multiplier x Actual FSB = CPU Speed
1:1 Ratio: 2 x Actual FSB = RAM Speed
1:1 Ratio: FSB = 1/2 RAM speed
QX9650:
Multi x Actual FSB, RAM Speed = Clock Speed
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Stock Speeds
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Easy OC
9 x 450Mhz, DDR2 900 RAM = 4.0Ghz <== Excellent OC
9 x 500Mhz, DDR2 1000 RAM = 4.5Ghz <== If you're EXTREMELY lucky
So any cheap set of DDR2 800 or DDR2 1000 RAM will be enough for the OC you want. I recommend this set:
G.Skill F2-8000CL5D-4GBPQ 2 x 2GB DDR2 1000 RAM - $85
Thank you for the advice. Does the rest of the system look good? Or is there some fat I can trim up a bit? Is 620 watt too much or can I get away with the 520hx instead. Thanks again.
The 620HX is not too much but you could get away with the 520HX. But go with the 620HX if you want a little bit more headroom for future upgrades.
I'm going with the Xigmatech and the retention bracket as tiraides suggested.
Just pretty good? C'mon I'm spending $1400 on this rig. Give me some good criticism.
Edit: That sounded scathing, didn't mean to be.
I was suggest adding a Raptor or a more speedier 10k+ rpm drive if your devoting it to gaming. Many forget that the drive is one of the parts that currently bottleneck modern systems. Although, you gotta account for the excess heat it may produce, but if your still gonna use the 900, then that's not really too much of a problem.
Spending upwards of $160 for a raptor drive for a minimal performance increase in real world performance over the WD 640 is not worth it. I don't wan to exceed my $1400 limit.
Personally, Raptors are overrated. The newer hard drives out now, particularly every drive that uses 320+GB drive platters, are fast enough to compete with the Raptor X hard drive. And for the cost of one 300GB VelociRaptor, you could purchase around 2TB of storage capacity. They're not that much of a bottleneck like you're trying to make them out as.
Do you really need us to hold your hand through this? I mean, "pretty good" is a great complement compared to, "are you out of your f%#@$& mind?!?"
I'll be ordering tonight, I will post pics and get updates for you all. My current rig:
AMD 64 3000+
2 GB PC3200
BFG 7800 GS OC (AGP)
lol, gonna be a great upgrade.
I think you've mistaken my intentions. I met current hard drives in general are a bottleneck. But if he's aiming for a gaming setup, then from my own experiences, a game loading off a Raptor will give a more considerable boost, then the drive with a 16mb cache he linked too. The max read/write speed has a higher throughput. I don't have any experiences with any drive with 32mb cache, so I can't comment on that.
I wouldn't knock the guy for getting too impatient with input. He sounds very excited since he's getting an updated system. after all.
I didn't mistake your intentions; I'm just saying that the OP wouldn't really benefit from getting a Raptor or a VelociRaptor. Check out this thread containing HD Tune benchmark scores for a variety of hard drives. Several people have the new Western Digital and Samsung HDDs and they compete with (if not outright beat) the last-gen Raptors.
