Quad core on the cheap - help me build!
jack9800XT
Hello all, been a while since I have been posting!
Starting school (again) and on a super tight budget but I need a new box to keep me occupied with some games maybe and for a fair bit of work. Aside from games it will be used for solidworks, autocad, programming, assorted other engineering applications.
After doing some research into newer tech I have decided on going with the Q6600 as my processor as I feel that it really gives the best bang for buck, especially since I will be doing some serious multitasking, but if you have any other suggestions go ahead.
This box will probably never be upgraded again for another year or two and when it does it will be from scratch. This just has to get me by for a while
I have an old box I can use to grab optical drives,hard drives if it will justify spending more on other components for a great increase in bang for buck. I could also get an old antec sonata case with no psu.
So far I have;
Q6600
GIGABYTE GA-EP45-DS3L LGA 775 Intel P45 ATX
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel
COOLER MASTER eXtreme Power Plus RS-460-PMSR-A3 460W ATX12V V2.3
WD5000AAKS 500GB 7200 RPM 16MB Cache SATA
A friend is going to donate a video card until I can raise the funds to get another so that is not a factor.
I need to get this as cheap as possible while maintaining
a) ability to get some overclock
b) quality on critical components- I really can't afford for this to fail
Thanks for the help guys.
Some of your items I like. But, needs some tweaking. BTW, what's the max budget you can go? Plus, where are you located? I see some of your links are going to NewEgg Canada and some are not?
yeah sorry my bad man, I am in Canada.
I would like to keep it under $500 if possible.
Danny meant "threat." Go with his build. ;)
The EP43-DS3L is cheaper, but out of stock.
