Q9550 + Hyper 212+ HSF = 76c full load... Too high?
lobski2
It primes successfully for hours (Although it fails IntelBurn).
It's currently at 446*8.5 ~3.7Ghz. RealTemp and CoreTemp both say full load is at 76c... Is this too high?
I probably wouldn't run it that hot -- not a 45nm chip. Drop a couple hundred MHz and a little vcore, and call it good. That HSF is nice, but it can be overwhelmed by a quad. You'd more ideally be using a TRUE120 / Megahalems / similar.
I never liked my Q6600 to run that hot, 70c was my mental cut off point.
What are your volts on that chip?
1.288 (Not sure of actual).
I think I'll reseat the heatsink tomorrow.
I think I should've applied the AS5 onto the heatsink plate instead of the CPU before screwing down the HSF. Oops.
Maybe ditch the AS5 and go to a more modern paste.
MX2 or MX3 will lower that temp from 3-6c depending.
Well, I would like to use up the remaining AS5 if possible. I haven't done any major oc/tweak work since Socket A. How times have changed, even applying the paste is different. (Spread on heatface instead of cpu dye)
Personally I would still grab some newer paste since the stuff is pretty cheap and can lower temps by a few.
Application doesnt matter. I put the paste on the cpu and my q9550 at 3.8 doesnt even reach 60c load with IBT. TMI brand wont make that big of a difference (altho I do use mx2). Either your heatsink is bad or you seated it wrong.
If it fails IBT it's unstable, post your full specs and BIOS settings. And no, 76C is NOT to high, this is a 45nm quad, it's TjMax is 100C, now if you were into the 80's you might want to think about stopping, but if my max temp was 76C I would have no problem running that OC 24/7.
Hyper N212 is a budget cooler. You might try adding a 2nd 120 MM fan for "push-pull"
My n212 is inadequate with a single fan for cooling my i7 920 at 3.7 GHz under 100% load - 80sC :p
- in fact, i can use the stock Intel cooler to get that high (high 80s C)
76 is way high... My Q9650 only gets that hot in IBT/LinX at 4.25ghz...
I don't suggest AS5 for Hyper 212+, TX-3 is best paste for this type of HSF.
Those temps are perfectly safe. A bit higher than normal perhaps, but you're not risking anything.
Thanks for the info all.
I think airflow is the problem... I've reseated it 5 times, using two different compounds, and they're still the same. I even added a 80mm fan, which helped a bit inside. I did some more tweaking, lowered the volts a bit, and I got it down to 72c full load. Hopefully using 72c 24/7 won't be a great deal.
I really need a new case. It's very cramped in there, lots of wires from the PSU blocking space. I even have 6 HDD's in there.
