Q9400 Mobo with 800DDR2 Memory
IntelOwnz
Someone find a motherboard under 150, maybe under 120, for a Q9400 that I can use DDR2 800 memory with. Does not need anything else, I don't care about USB ports or raid. I will be using this for a slight OC and it's going in a gaming rig
k go.
k go.
DFI Q9400 Mobo - LANPARTY JR GF9400-T2RS http://www.dfi.com/portal/CM/cmprod...sWindow?action=e&windowstate=normal&mode=view
Giabite Q9400 Mobo - GIGABYTE E7AUM-DS2H
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2946
XFX NVIDIA GeForce® 9300 - Cheap anf good looking.
http://www.xfxforce.com/en-gb/products/motherboards/NVIDIA GeForceseries/NVIDIA GeForce® 9300.aspx
Do you mean a board to use a Q9400 CPU in or with the GeForce 9400 graphics?
I ended up buying a gigabyte board, thread closed. no one responded quickly enough, sorry
And the Gigabyte board was DOA from newegg, yay
Currently looking at the options here, ordering Sunday night
if you are going to overclock a 45nm quad, get a p45 board. dfi makes several below $120, and all are good. if you had read the specs of the board that you previously bought a little closer, you would have seen that it was, in fact, a gigabyte!!! so make sure to look a little closer, you wouldnt want to end up with something that could turn out to be, lets say, an asus!! also, this is an excellent board
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200280 50001402 1070509908&name=EVGA
You told me to buy a DFI and link me to EVGA boards..
I'm so confused lol
Don't pay too much attention to his suggestions. He hates ASUS and Gigabyte boards for some reason even though they are some of the best out there.
Well I now hate Gigabyte too, bought 2 of them and both one was DOA and the 2nd had a horrible voltage issue that almost fried my processor
you are now on the path to enlightenment. i didnt link you to the dfi boards because there are so many. i meant that besides the dfi boards, that evga is a good one, too. i have the slightly better version of it for over a year now. that would be this one
http://www.ewiz.com/detail.php?p=MB...1bf687f2bdf07d7f72f90782fa22cc678d67beb89de34
here are the dfi boards i was typing about
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136060
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136055
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136053
i have never used the blood iron, but i have used the last 2 dfi boards, the lp jr (micro atx) and the lp dk p45 personally, with a 45nm quad, and they work great. as far as paying attention to my recommendations, nothing i have recommended to you has burnt up and almost zorched your cpu.
that looks like a nice board. I had the older P5Q Pro board and it worked great with a Q9300 and now a Q9550. If I were going to replace it, I'd think about that board.
Will be here tomorrow, will report back soon!
Well folks, the Asus board booted right up = win
I hate Gigabyte motherboards
Thanks, thread closed.
