at that price you should get a q9550 or a e8500. there is a member here selling e8500 new in box dirt cheap. I got one from him.
I went from a q600 to a e8500 just cause of gaming. its been working great so far!
The late batches of the Q6600 didn't overclock very well. I'd take a 45nm CPU instead.
I purchased my Q6600 SLACR nearly 2 years ago now......never overclocked it. I assume it would be a good OC'r though as it was an early batch. My FPSs and video encoding still don't overwhelm it so, oddly enough, I have little itch to upgrade to anything in the CPU area.
You do know what an FSB is, right?
i wanted something fast that would run cool in the summer
Why are you overclocking with EasyTune?![]()
he could have just been showing us his voltage settings Captain Assumptions.
Go with a 45nm.., the 6600 is getting a bit dated.![]()
I just hate having a broiling hot bedroom. The Q6600 is still perfectly adequate for gaming and such @ 2.4 GHz.hot outside->hot room->higher temps for your CPU->possible instability.
I'm still very happy with my Q6600.
my 6600 is G0 and it runs really cool (32C - 40C) at stock speed.
Mine's a B3. Between it and the HD 4890 my water loop dumps a lot of heat into the room.
Like I said, I'm not concerned about hardware temps, I'm concerned about me.Personal comfort before overclocking.
How so?
Did you just arbitrarily look at a calendar and decide that the chip is old now? As opposed to, you know, judging the chip based on it's own merits?
Because let's be realistic here, it's all "a bit dated" compared to i7, so if you are set on a 775 rig anyway there is really no reason to not go with a Q6600 if the price is right.
