enyceexdanny
- Sep 22, 2003
My settings are below.
I have it overclocked at 3.2ghz. After about 14 mins in to prime95. one of the cores had an error. Not sure if I should raise the voltage more..
* EDIT 3:51 | 8/24/07 *
Raised the vcore to 1.3550v. Lowered all the rest except vdimm to defaults.
Vdimm is at 1.850v.
Currently a tad longer than an hour on prime95 with no errors on any of the cores as of yet.
Temps via coretemp are 63,61,63,61 on cores 1,2,3 and 4 -respectively.
What should I do next? You think I can go more without killing my cpu early?
Also, for some reason cpu-z shows my vcore as lower.. When in fact, I raised it..
*END EDIT*
Prime95 small FFT Load
• 400 fsb x 8 multiplier
• VCore - on bios: 1.325v | on cpu-z 1.312
• DDR2 - 1.850v Running at 4-4-4-12 1T
• MCH - 1.29v
• PCI-E - 102mhz
My load temps currently are read via core temp 0.95 and averaging at 60c.
Idle being approx. 40c
First, I'm not too sure about the voltages and their limits per cpu, mch, and etc.
It would be great if I can get some insight on that.
Second, my next step would be 3.4ghz and finally my goal is 3.6
But I'm kind of worried about the temps. I'm not sure if 60c on load is really hot or not.
What do you guys think? I would be grateful if someone can provide how I should go on about the bios settings regarding the speeds and voltages.
Third, does it make a difference having the FSB running so high? I'm currently at 1600. Are there any benefits? The cpu is rated at 1066 right? So what effect does it have?
That's it for now.
Thank you in advance. >_<
