rampantandroid
- Jun 14, 2006
I know, people say the 680i is terrible for OCing...I can't even do 2.7 GHz on my Q6600, B3 stepping with a Thermaltake V1 cooler.
I can hit 2.6 GHz on the default voltages, but if I go to 2.7, windows either just won't boot, or my BIOS will freeze, or go into safemode with a multiplier of 6x. I've tried upping the voltage (went as high as 1.26 in BIOS, the NV overclock util claims I am at 1.8v?!) and upped the FSB to 1.5V....but I still can't hit 2.7 GHz and even boot.
Am I doing something wrong? I'm trying this by setting the FSB & memory to unlinked, leaving my RAM, Corsair DHX 4 GB set (2 x 2GB, 5-5-5-15) DDR2-800 at its default settings, and then inching the FSB up, leaving the multiplier at 9x. Should I go around this by instead dropping my multiplied to 8x and upping the FSB to see if I can even hit 300MHz?
What voltages should I be going to? Am I better just getting a new mobo/CPU (Nehalem won't be cheap I'm guessing, and means new RAM as well...which will cost more than 500 USD, which I just DO NOT feel like)? I'm trying to OC, as my GTX280 seems to be held back by my CPU...but this just isn't going well for me. I'd just grab a new 45nm CPU, but this shitty 680i can't handle 45nm quads...should I just get a P45 or X48 and a Q9550?
