OlIv0rIolI
- Dec 2, 2005
Hi, I am going to be building a new rig soon and I need a little help for water cooling. Here are my system specs
Q6600 (like half the people on this forum)
P35 motherboard, still debating between p5k deluxe or abit
2*1 gig pc6400 cas4 ram ( what’s a better overclocker cosair xms or crucial ballistix ?)
7900gs, not too big on dx10 or too much gaming
Thermaltake tough power modular 750 watts (is it overkill?, reliable, trustworthy psu?)
P182 case
My planned wc setups so far is
d-tek fusion or apogee gtx wb
Swiftech MCP655 pump
½” tubes or maybe 7/16”
I am only going to include cpu in my loop as of now. I might add graphics and chipset blocks later. My buget is under 300 dollars. My goal is to overclock up to 3.2ghz while keeping the temp under 26 idle, 45 load therefore low noise levels.
My questions are
1: the d-tek fusion is unsymmetrical as in the inlet is in the center and the outlet is offcenter, so wouldn’t that create uneven cooling and hotspots especially on a quad? Apogee doesn’t seem to have that issue.
2: How big should my radiator be? I am thinking 240 is enough and is it better to get two 120 rad or 1 240 rad? Also since I think I am getting a p182, how should I fit the rad in it? Any pics would be helpful.
3: I like to turn my comp off when I go to sleep, just because I don’t like to waste energy if I don’t have to. So does this effect water cooling setup negatively in any way? Or my comp for that matter?
4: Is the swiftech pump enough or too much? can I get something cheaper?
5: Is it necessary to add a chipset block for my overclocks or just a fan is ok?
Any suggestion and advice are welcomed. I am not looking for extreme overclocks, just as much as possible while keeping the cpu cool. This is my first water cooling setup and I hope you guys can help me out here, thanks
P182 case
My questions are
