Q and A Session! (system build ?'s)
threeDguru
Well I have been out of the computer building scene for awhile and was looking to build my next computer. Couple questions and maybe if some of you could point me in the right direction.
Heres The Questions
Gaming/Photo Editing
$1200 before shipping
3) Where do you live?
Texas
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
N/A
WD Raptor 74gb 10k rpm
6) Will you be overclocking?
No
19" LCD Samsung 930b
Next week in next month (2-4 weeks)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing Fancy, Crossfire Compatible
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
With $1200 budget, most would recommend an Intel Core i7 build. But, out of curiosity, what is your current setup?
Haha here we go
Intel Pentium 4 Prescott 3.0 ghz
Asus P4
Corsair XMS 1GB PC3200
Nvidia 6800 Ultra
WD Raptor 74gb
Sony DRU-720A DVD-RW
Old System built about 3 years ago, still plays games but is lacking finally.
My goodness, anything would be a major upgrade to that. Do you plan on upgrading your monitor? Or, are you fine with that Samsung 19"?
the 19" is perfectly fine no image ghosting or anything
EDIT** Maybe a larger monitor could be nice, say 22" or something
What would you recommend, like I said im not sure what to look for and im totally in the dark ages
CPU/MOBO - Intel Core i7 920 + Gigabyte GA-EX58-UD4P both for $515 ($20 MIR on mobo)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.193606
RAM - A-DATA 6GB DDR3 1600 for $84 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211377
PSU/VIDEO - Antec EA650 + EVGA Gefocre GTX 260 (216) both for $240 ($25 MIR on video card)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.194124
HDD - WD6401AALS 640GB for $75 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
OPTICAL - Samsung 22X Sata DVD Burner for $24 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151176
CASE - Antec 300 for $55 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
MONITOR - Acer X223Wbd 22" for $150 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009145
Total: $1,143 before shipping & taxes
This is just 1 example. There is other builds that can be put together. But, I think this is pretty solid as is.
Go with HardwareGuru's build -- no need to overthink things there.
Keep your Samsung 930b to use as a second monitor for Photoshop.
Here's another pretty solid setup
VIDEO/CPU - Sapphire Radeon HD 4870 1GB + Intel Core i7 920 both for $445
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.186986
MOBO - ASUS P6T SE X58 for $206 w/free shipping
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10010451
PSU - PC Power & Cooling 750watt for $100 w/free shipping $30 MIR)
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005611
Total: $1,139.00 before shipping & taxes
Thems some pretty good deals.
I was trying to one-up you but I dont think I can....
or maybe I can:
Foxconn X58 "Flaming Blade"
- $180
- Horrible name
Newegg Ci7 920 + EVGA GTX 260 combo
- $445
- 55nm GT200
- free COD:WAW
BFG LS 550W
- $80 before $20 MIR.​
_________
$704.96 (where HardwareGuru was $750... and I like my PSU better :p)
edit: actually I dont know about that motherboard, its layout is terrible and it only has room for 6GB ram (not that you'd need any more)...
The weakest point is the hard drive: Only 10% faster than the WD 640GB Black drive that was mentioned earlier yet costs $110 more. That extra 10% performance increase is not worth $110 IMO.
I would also recommend getting the GTX260 since its performance is similar to that of the HD4870 but it comes with better support and a lifetime warranty from one of the big three:
$170 - BFG Tech BFGEGTX260896OCE GeForce GTX 260 896MB PCI-E Video Card
I'd go with the Corsair 750TX since it's $10 cheaper and is of equal quality to the PC P&C Silencer 750:
$110 - Corsair 750TX 750W PSU
+1
You also get allot more room with the WD640.
Noted, What about the motherboard any pros or cons or suggestions?
For some reason, I'm getting the vibe that the MSI X58 Pro is a bit on the low-end. No actual proof but a nagging little thought.
So what would one recommend for a mobo?
The ones that have already been suggested:
Asus P6T or P6T SE
No need to go to the higher models, since you don't need anything fancy.
I agree, ditch the raptor. If you want speed, get a couple OCZ Vertex 30GB SSDs when they're on sale for $90AR and throw them in RAID0... now thats pricey storage, but will blow away any mechanical hard disk array. ;)
http://www.alphaq.org/enginurd/hdd/new.html
Go with HG's first build. The A-Data RAM is fine. If you're uncomfortable with it, get the G.Skill instead.
