PWM water pump control
Auraka
What is the dominant strategery controlling D5 water pumps? I'm running a WaterCool Heatkiller 150 tube/pump combo. Are you guys picking a present curve and running with it, custom curve, 100% or some other chosen value?
Sorry I've no idea :D
I have a Koolance manual pump controller that I make adjustments with. I stopped worrying about pump speeds a long time ago. As long as I can effectively purge my loop and keep the micro bubbles from re-entering my loop over and over(maddening) I'm gtg.
Dual d5s.
Noise is my priority for my loop. My current pump is only on/off, but I would set it to the highest inaudible setting and let it sit there if I could. Maybe set a curve to peak in extreme conditions to prevent throttling, but that's about it.
