Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Hey,
I am working on a project in which I need to be able to manually control pwm signals for fan control.
There used to be a device for PC's that did this, the Zalman PWM Mate, but they must have discontinued it, as I can't find it on Amazon, Newegg or eBay...
Does anyone know of a current device that can do this? There are a lot of cheap PWM signal generator boards on eBay, but I have gathered that now all PWM is the same, and I need one with the frequency range that the PC fan specification uses. Does anyone know how to select one that might work?
Thanks,
Matt
Thanks,
Matt
