System:
Q6600 G0
Abit IP30 Pro
Patriot low latency PC6400 (2x1gig)
Tuniq Tower
FSP Bluestorm II
Evga 8800gts 640mb
I'm still fairly green at overclocking, so bear with me on some of this stuff.
I had the rig running at 3.2Ghz (8x400) for over 12hrs stable running blend tests in Prime95. Vcore was adjusted in BIOS to 1.32v and memory was 4-4-4-12 @2.2v. Idle temps were in the mid 30's with load in the upper 50's/low 60's.
I decided to play around with it some more and was able to hit 3.6Ghz (9x400) but I had to increase the vcore in BIOS to 1.50v (showed 1.42 in CPUZ after vdroop). I had it running Prime for a little over 20mins and was seeing temps in the upper 60's and then got an alarm beeping for PWM being at 80C, so I shut down the test.
Not liking those temps, I decided to see if I could get it better at 3.4Ghz (8x425). I was able to lower vcore down to 1.40 in BIOS (1.36v in CPUZ after vdroop), temps under load were a little better also. Memory is still at 4-4-4-12. I went to bed while Prime95 was running a blend test. Five hours later I was awoken by another PWM temp alarm going off because it was hitting 80C. I shut down Prime, which had showed no errors and been stable for a little over 5hrs.
What's the deal with PWM temps? Is 80C the max? My case has great airflow. I have two Yate Loon 12cm intake fans, a 12cm blowhole fan, a 12cm rear exhaust fan, the PSU has a 12cm fan and so does the Tuniq. I have another fan I was going to add by drilling a hole in the case side and mounting it down low to blow partly on my video card and partly on the northbridge. I can't mount it any higher since it'll interfere with the Tuniq.
Q6600 G0
Abit IP30 Pro
Tuniq Tower
FSP Bluestorm II
Evga 8800gts 640mb
