- Oct 29, 2000
Hey all,
In my cooling setups, I am a huge fan of using PWM control to let the system be as quiet as possible, unless needed.
How do you handle this when you add a GPU to your loop.
I have seen mini GPU fan to full size 4 pin fan converters, so it IS possible to read the PWM signal off the GPU, but what does one do with it.
Now we have two (or more, if multi-GPU) PWM signals to control fans for one loop.
Is there any type of device that can take multiple PWM inputs and only pass along the highest one to the fans (I know this could probably be programmed on an Arduino, but I am not a programmer, and I have no Arduino experience.)
What do you guys do with your systems?
