I'm having a total brain fart right now.
I have non-PWM case fans. I want to run them off of the motherboard headers (which are PWM capable) that way they are dynamic PWM and can change with cooling curves via software.
I need an adapter that plugs in to the motherboard header, uses the PWM signal from the motherboard, and gives you the modulated output I can plug my fans into.
What are these called!?
