Put CPU shim on sideways, won't boot
Rizen
So I had a Mobile 2600. I was installing my SI-97, and I removed part of the sticker covering a few bridges on the top of the CPU, and installed the shim then the heatsink. Won't boot. I try a lot of things, no go.
I remove heatsink, the shim was installed 90 degrees off, to the left, so part of the copper had been covering the traces. I put it the right way, reinstall heatsink.
Still won't boot =\
Did I fry my CPU? My system is in my sig.
Please help :(
go to amds corporate website
www.amd.com
in the search box lookup "rma presentation"
there will be a link for the RMA presentation.pdf form
in that form is a "how too" that will show you how to test for a shorted cpu.
shims were only meant for CPGA, classic athlon and durons, they were never meant nor recommended for OPGA substrates...that would be the newer socket A cpu's
MD
